How to detect the CPU is INTEL or others?
free1006
I want to set the KMP_AFFINITY to NONE for AMD CPU, but don't know how to detect the CPU is INTEL or others.
I have tried somes windows API, seems not works.
Could some provide a code to me ?
Note: I don't want to use the WMI.
SergeyKostrov
Valued Contributor II
Quoting free1006
Could some provide a code to me?
In case of using a'__cpuid' instruction you could look for a Vendor information:
RTint CPUInfo[4] = { -1, -1, -1, -1 };
RTchar CPUVendor[32] = { 0x0 };
RTuint nIds = 0;
__cpuid( CPUInfo, 0 );
nIds = CPUInfo[0];
CrtMemset( CPUVendor, 0x0, sizeof( CPUVendor ) );
*( ( RTint * )( CPUVendor )) = CPUInfo[1];
*( ( RTint * )( CPUVendor+4 )) = CPUInfo[3];
*( ( RTint * )( CPUVendor+8 )) = CPUInfo[2];
CrtPrintfA( "\tCPU Vendor : %s\n", CPUVendor );
and output could look like:
CPU Vendor : GenuineIntel
Sergey
free1006
Thank you very much.
Thomas_Jensen1
Its not KMP_AFFINITY=NONE but KMP_AFFINITY=DISABLED
I use (Delphi):
if CPUID.CpuType<>CPU_TYPE_INTEL then
SetEnvironmentVariable('KMP_AFFINITY','disabled'); // to disable annoying cmd box on non-Intel systems...
CPUID is a global object from the JCL library (opensource).
SergeyKostrov
I wonder how a call to a'__cpuid'will work on a computer with AMD CPU? Could somebody try it?
free1006
I have tried, the KMP_AFFINITY=DISABLED is not works, the KMP_AFFINITY=NONE works fine.
Thomas_Jensen1
Sorry, I should be more precise: since IPP 7.0.7, KMP_AFFINITY=DISABLED is the correct way, between 7.0.0 and <=7.0.6 KMP_AFFINITY=NONE is correct.
