When I run my application which built base on the INTEL IPP on an AMD CPU, got the warning message, please see the attached screenshot. Please tell me how to remove it, thanks in advance.
- « Previous
- 1
- 2
- Next »
I don't understand, If I use the latest compiler and IPP 7.1, is the problem fixed (Meaning I shouldn't care at all which CPU is being used)?
Or still the KMP property should be set?
Hi Royi,
Yes, the problem should be fix. From the issue's record,
Redo fix for DPD200175816. Suppress warning if KMP_AFFINITY=none
or KMP_AFFINITY=disabled, as welll as if KMP_AFFINITY is not set.
So whatever the CPU is, the warning is suppressed.
Ying
Topic Options
- « Previous
- 1
- 2
- Next »
