How to use ippInitCpu(ippCpuSSE3) in IPP 9.0
sumit_j_
Hi All,
I have working with code which is using following  IPP-6.0 API
IppStatus status = ippInitCpu(ippCpuSSE3);
 if (status != ippStsNoErr)
     throw IPException(SOURCE, "ippInitCpuFailed - %s", ippGetStatusString(status));
For some reason I am forcing CPU to use SSE3. But the latest ipp library  -IPP_2017_3_210 – doesn’t have these function and neither IPP legacy has this. But, I want to  force CPU to use SSE3 in latest IPP version but I am not getting the right way of doing it.
I read IppInit() activates CPU based on system configuration but it doesn't talks about forcing some particular setting.
Plz suggest how I can use latest IPP API to achieve same thing.
Sumit Jha
BMart1
New Contributor II
I think you need ippSetCpuFeatures.
sumit_j_
HI Bruno,
I know that i can use "ippSetCpuFeatures" this get same result  but i don't how to use  it for same. I need some sample/example.
Sumit Jha
Shaojuan_Z_Intel
ippSetCpuFeatures(ippCPUID_SSE3)? Is this what you are looking for?
sumit_j_
Hi Shaojuam,
I was using ippSetCpuFeatures(ippCPUID_SSE3) as follows-
status = ippGetCpuFeatures(&cpuMask, 0);
if (ippStsNoErr == status)
enabledCpuMask = ippGetEnabledCpuFeatures();
if ((enabledCpuMask & ippCPUID_SSE3) && (cpuMask & ippCPUID_SSE3))
 status = ippSetCpuFeatures( ippCPUID_SSE3);
But , this is giving error by error status - ippStsFeaturesCombination
so I am using -
Ipp64u M7_FM = ippCPUID_MMX | ippCPUID_SSE | ippCPUID_SSE2 | ippCPUID_SSE3;
status = ippSetCpuFeatures(M7_FM); // ippCPUID_SSE3;
This works fine.
Can you tell me why  "ippSetCpuFeatures( ippCPUID_SSE3);" is failing but other  is working fine.
sumit jha
Igor_A_Intel
hi Jha,
ippStsFeaturesCombination is not error status - all error statuses are < 0, and warnings are > 0. This warning just tells you that SSE3 can't be enabled solely without SSE and SSE2 and that these features will be enabled too.
regards,Igor
sumit_j_
Hi Igor,
Thank you for your reply.
Just for clarification, basically you are saying to enable SSE3, I need to enable other dependency too.
Following code does same and hence it is correct.  Am i right ?
What will happen if I ignore this warning and do only
status = ippSetCpuFeatures(ippCPUID_SSE3);
Sumit Jha
Igor_A_Intel
Hi Sumit Jha,
in this case all previous SSE extensions will be enabled automatically - SSE3 code can't work without SSE2 and SSE as is inherited from them. Therefore you can ignore this warning.
Regards, Igor
