How to use ippiLUT8u_C3IR
ido_t_
Hi.
I would like to use IppiLUT (ipp 9.0) to convert input rgb image (unsigned 8 bit) to different rgb image values.
So i need LUT with input size of 256*256*256 = 16MB and output size of 16MB * 3 (16MB output r, 16MB output g, and 16MB, output b)
Do you have any example to use ippiLUT_Init_8u for such case?
I'm not sure how should pValues and pLevels arguments to the the init function should look like.
IppStatus ippiLUT_Init_8u(IppiInterpolationType interpolation, IppChannels channels, IppiSize roiSize, const Ipp32s* pValues[], const Ipp32s* pLevels[], int nLevels[], IppiLUT_Spec* pSpec);
Ido
Jing_Xu
I'm sorry but I don't quite follow this line. Could you make a simple example?
