the encode func is ippiBGRToYCbCr420_8u_AC4P3R
here a part of my code, the question are below
// how to fill aviStreamInfo?
// how to fill aviCompressOptions?
//how to fill bitmapInfoHeader?
#define FRAME_LOCKBUFFER( PTR_FRAME, PTR_FUNC, PTR_DATA )
do
umcSts = PTR_FRAME->PTR_FUNC( &PTR_DATA );
if ( ( UMC::UMC_NOT_ENOUGH_DATA == umcSts )
|| ( UMC::UMC_NOT_ENOUGH_BUFFER == umcSts ))
vm_time_sleep(5);
} while ( ( UMC::UMC_NOT_ENOUGH_DATA == umcSts )
|| ( UMC::UMC_NOT_ENOUGH_BUFFER == umcSts ));
if ( UMC::UMC_OK != umcSts )
break;
#define FRAME_UNLOCKBUFFER( PTR_FRAME, PTR_FUNC, PTR_DATA )
break;
struct IPPSpec_Infos_t
// path info
TCHAR FileAvis[MAX_PATH];
TCHAR Paths[MAX_PATH];
// encoder info
UMC::VideoEncoder*pEncoder;
UMC::VideoEncoderParams*pParams;
UMC::SampleBufferVideoFrames[1];
UMC::SampleBufferCompressedFrames[1];
// encoder spec
UINTSpecFmt;
UINTSpecFilter;
// capture buffer spec: backbuffer
Ipp32sSnapPitch;
Ipp32sSnapInPitch;
boolSnapResize;
IppiSizeSnapDest;
IppiFactorSnapFactor;
IppiSizeSnapViewport;
//Ipp32sSnapByte;
//Ipp32sSnapPitch;
//IppiSizeSnapCanvas;
// thread info
vm_threadhTh
rSave[1];
vm_threadhThrEncoder[1];
vm_eventhThrEtExit[1];
vm_eventhThrEtSave[1];
vm_eventhThrEtEncoder[1];
// frame info
floatnFrameRate;
floatnFrameWeight;
UINTnFrameCapture;
UINTnFrameRecord;
vm_ticknFrameTimes;
vm_ticknFrameFrequency;
UINTnFrameSave;
UINTnFrameEncoder;
UINTnFrameSampling;
unsigned int IPP_ThreadSaveing( void* Parameter )
// get spec info pointer
IPPSpec_Infos_t* pSpecInfo = ( IPPSpec_Infos_t* )( Parameter );
assert( pSpecInfo != NULL );
// init local info
UMC::VideoEncoder* pEncoder = pSpecInfo->pEncoder;
UMC::VideoEncoderParams* pParams = pSpecInfo->pParams;
UMC::VideoDatacompressed_data;
UMC::StatusumcSts = UMC::UMC_OK;
HRESULT hr = E_FAIL;
AVIFileInit();
AVISTREAMINFO aviStreamInfo;
PAVIFILE pAviFile = NULL;
PAVISTREAM pAviStream = NULL;
PAVISTREAM pAviCompressedStream = NULL;
AVICOMPRESSOPTIONS aviCompressOptions;
BITMAPINFOHEADER bitmapInfoHeader;
pSpecInfo->nFrameSave = 0;
hr = AVIFileOpen(&pAviFile, pSpecInfo->FileAvis, OF_WRITE | OF_CREATE,NULL);
if ( !pAviFile )
AVIFileExit();
return 0x1001;
hr = AVIFileCreateStream(pAviFile, &pAviStream, &aviStreamInfo);
if (!pAviStream)
AVIFileClose(pAviFile);
AVIFileExit();
return 0x1001;
hr = AVIMakeCompressedStream(&pAviCompressedStream, pAviStream, &aviCompressOptions, NULL);
if (!pAviCompressedStream)
AVIStreamClose(pAviStream);
AVIFileExit();
return 0x1001;
hr = AVIStreamSetFormat(pAviCompressedStream, pSpecInfo->nFrameSave, &bitmapInfoHeader,sizeof(bitmapInfoHeader));
// for
HANDLE hEventWait[] = { pSpecInfo->hThrEtSave[0].handle, pSpecInfo->hThrEtExit[0].handle };
DWORD hEventCount = 2;
while ( true )
DWORD hWait = ::WaitForMultipleObjects( hEventCount, &hEventWait[0], FALSE, INFINITE );
if ( hWait != WAIT_OBJECT_0 )
break ;
vm_event_reset( pSpecInfo->hThrEtSave );
while ( UMC::UMC_OK == umcSts )
// get source buffer
FRAME_LOCKBUFFER( pSpecInfo->CompressedFrames, LockOutputBuffer, compressed_data );
hr = AVIStreamWrite(pAviCompressedStream, // stream pointer
pSpecInfo->nFrameSave, // time of this frame
1, // number to write
compressed_data.GetDataPointer(),
(long)compressed_data.GetDataSize(), // size of this frame
AVIIF_KEYFRAME, NULL, NULL);
compressed_data.SetDataSize(0);
FRAME_UNLOCKBUFFER( pSpecInfo->CompressedFrames, UnLockOutputBuffer, compressed_data );
pSpecInfo->nFrameSave ++;
AVIStreamClose(pAviCompressedStream);
AVIFileExit();
return UMC::UMC_OK;
thank you very much!
I'm glad you solve your issue :)
Vladimir
![](/skins/images/7FC17B7B85029576C25F1E43CE255B51/responsive_peak/images/icon_anonymous_message.png)
