IPP 2D convolution work properly on demo data only
alexandr_s_
I have a question.
There are two functions of 2D convolution in attached cpp-file.
The first one is a standard convolution on floating-point data.
The second is a function, that use ippiConvValid_32f_C1R() for convolution.
When I use data of this example (https://software.intel.com/sites/products/documentation/doclib/ipp_sa/80/ipp_manual/GUID-DB033BE0-5621-4C7A-AA34-B8E0BCA74B0C.htm) with integer numbers for source matrix and kernel, everything is ok, results of two functions are equal, but when i use generator of random integer or floating-point numbers, ippiConvValid_32f_C1R() returns wrong result.
What's the problem?
Chao_Y_Intel
Which version of Intel IPP are you using now?
ippiConvValid_ functions is deprecated, could you use the ippiConv_xxx as the replacement?
Chao
alexandr_s_
I have downloaded last demo version IPP two weeks ago.
I would like to buy the license if it will work properly.
Now, I have tried to use the function ippiConv_32f_C1R(...) instead ippiConvValid_32f_C1R(...), but i get the same result.
I noticed, when i am using the kernel and src1 from example(https://software.intel.com/sites/products/documentation/doclib/ipp_sa/80/ipp_manual/GUID-F26546FF-2F62-4CC2-888E-9849C8D0DE78.htm), both functions are working properly, but if I try to change at least one number in the kernel, thus disrupting its "symmetry", I get absolutely wrong result. What else can i do?
Igor_A_Intel
Hi Alexander,
I guess you've implemented correlation instead of convolution - Ii think that if you perform a mirroring of your generated kernel (so that right bottom pixel becomes the left top) for your function (or for IPP) - you'll get the expected and comparable result.
regards, Igor
alexandr_s_
I don't quite understand, what you mean?
alexandr_s_
In the documentation for the function I see the formula
I need the exactly this formula for convolution, not for correlation. In documentation I don't see any limitation that kernel should be mirrored (symmetric).
Igor_A_Intel
Hi Alexander,
I've said nothing about symmetry. It's seen from the formula that kernel (g in the formula) is applied from the top index to bottom. So for your implementation of convolution (I guess) you should perform kernel transposition in the next manner:
k00,k01,k02
k10,k11,k12
k20,k21,k22
to:
k22,k21,k20
k12,k11,k10
k02,k01,k00
regards, Igor
alexandr_s_
Hi, Igor,
After transposition of the kernel, you recommended, it works!
Thank you so much!
