IPP 5.3 and uclibc
glemarec
I currently migrate an embedded application from Geode CPU to Atom CPU.
I would like to use IPP to speed up audio signal processing but our linux target used uclibc instead of libc (target generated by Openwrt).
Is there a way to link IPP against uclibc ?
Any ideas ? technical solutions ?
Thanks in advance
Christophe
Vladimir_Dudnik
Hi Christophe,
we did not test IPP against ulibc. What kind of issues do you currently have with IPP and ulibc?
IPP itself use C run-time in minimal way, moslty only memory management functions, like malloc and free, used internally.
Vladimir
glemarec
Hi Vladimir,
Thanks for the answer.
Currently, I have no problem as it's not yet tested.
Maybe I cry before to be hurt, I just checked for possible problems as link against uclibc was the main source of problem we encounter with other lib/package.
I will test this next week and keep you informed.
Christophe
