After IPP 5 install I've tried to recompile IPP 4.x projects ( like Mpeg2Decode ou IJL , ..etc) and this can't be achieved. Some funcs have just new names like IppCoreGetCpu() that is now IppCoreGetCpu()..., some others are just lost somewhere like IppStaticFree() -- but I still got IppStaticInit()...-- or like plane conversions used for Mpeg2. I've not yet tried new samples has my first concern is on retro-compatibility. So my question is can we expect final 5.0 version support execution & recompilation of previuous work ?Or are we again in the quite same situation as from IPL to IPP ?
SRSR
oops. I've found my answers : in IPP 5 you have 2 text files enumerating new functions (added) and old (removed) functions : they are located in doc folder : ipp_API_add.txt & ipp_API_remove.txt.
my question is : can you confirm that < ippStaticFree() > is not more necessary after ?.
In IPP5 you can still find documentation for usage ....
SRSR
Yes. You can check there 2 new documents to find new API and removed APIs in IPP 5.0 beta.
The document is needed to correct. I will send request to our documentation owner to fix these in next release. If you find more document errors in our documents, please report us via Intel Premier Support.
Ying
Ying
