IPP Convolution
KIM__ILTAEK
I am testing the convolution using IPP.
I also tested using MKL, but it was not as fast as I thought. However, when implemented simply with IPP, incorrect results were output.
I would like the result of the link below, but please review what's wrong.
https://software.intel.com/sites/default/files/did_feeds_images/0EF01A88-F874-4ECB-B2B6-3ADC38636CD4/0EF01A88-F874-4ECB-B2B6-3ADC38636CD4-imageId=B62A36F3-9673-4469-A2A2-C62788A26EB4.jpg
    const int out_width = 5;
	const int out_height = 9;
	IppStatus status = ippStsNoErr;
	Ipp16s* pSrc1 = NULL, *pSrc2 = NULL, *pDst = NULL;			/* Pointers to source/destination images */
	int srcStep1 = 0, srcStep2 = 0, dstStep = 0;				/* Steps, in bytes, through the source/destination images */
	IppiSize dstSize = { out_width, out_height };				/* Size of destination ROI in pixels */
	IppiSize src1Size = { 3, 5 };								/* Size of destination ROI in pixels */
	IppiSize src2Size = { 3, 5 };								/* Size of destination ROI in pixels */
	int divisor = 1;											/* The integer value by which the computed result is divided */
	Ipp8u *pBuffer = NULL;										/* Pointer to the work buffer */
	int iTmpBufSize = 0;										/* Common work buffer size */
	int numChannels = 1;
	IppEnum funCfgFull = (IppEnum)(ippAlgAuto | ippiROIFull | ippiNormNone);
	pSrc2 = ippiMalloc_16s_C1(src2Size.width, src2Size.height, &srcStep2);
	pSrc1 = ippiMalloc_16s_C1(src1Size.width, src1Size.height, &srcStep1);
	pDst = ippiMalloc_16s_C1(dstSize.width, dstSize.height, &dstStep);
	do {
		status = ippiConvGetBufferSize(src1Size, src2Size, ipp16s, numChannels, funCfgFull, &iTmpBufSize);
		if (ippStsNoErr != status)
			break;
		pBuffer = ippsMalloc_8u(iTmpBufSize);
		pSrc2[0] = pSrc1[0] = 1;
		pSrc2[1] = pSrc1[1] = 1;
		pSrc2[2] = pSrc1[2] = 1;
		pSrc2[3] = pSrc1[3] = 1;
		pSrc2[4] = pSrc1[4] = 0;
		pSrc2[5] = pSrc1[5] = 0;
		pSrc2[6] = pSrc1[6] = 1;
		pSrc2[7] = pSrc1[7] = 1;
		pSrc2[8] = pSrc1[8] = 1;
		pSrc2[9] = pSrc1[9] = 0;
		pSrc2[10] = pSrc1[10] = 0;
		pSrc2[11] = pSrc1[11] = 1;
		pSrc2[12] = pSrc1[12] = 1;
		pSrc2[13] = pSrc1[13] = 1;
		pSrc2[14] = pSrc1[14] = 1;
		status = ippiConv_16s_C1R(pSrc1, srcStep1, src1Size, pSrc2, srcStep2, src2Size, pDst, dstStep, divisor, funCfgFull, pBuffer);
			break;
		for (int j = 0; j < out_height; j++) {
			for (int i = 0; i < out_width; i++) {
				cout << pDst[i + j*out_width] << " ";
			cout << endl;
	} while (false);
	ippsFree(pBuffer);
	ippiFree(pSrc1);
	ippiFree(pSrc2);
	ippiFree(pDst);
Andrey_B_Intel
Hi KIM, ILTAEK.
The IPP library uses a so-named "step" between lines because the processed region can be part of big image.  I am attaching changes how to work with steps to get expected result.
 #include "ipp.h"
 #include <stdio.h>
void main()
    Ipp16s img[5][3] = { {1, 1, 1},
                         {1, 0, 0},
                         {1, 1, 1},
                         {0, 0, 1},
                         {1, 1, 1} };
 do {
         break;
     int w, h;
     for (h = 0; h < 5; h++) {
         for (w = 0; w < 3; w++) {
             pSrc1[h*(srcStep1 / 2) + w] = img;
             pSrc2[h*(srcStep2/2)+w]     = img;
         break;
             printf("%d ",  pDst[i + j * (dstStep/2)]);
         printf("\n");
 } while (false);
 ippsFree(pBuffer);
 ippiFree(pSrc1);
 ippiFree(pSrc2);
 ippiFree(pDst);
Andrey_B_Intel
Hi KIM, ILTAEK.
 #include "ipp.h"
 #include <stdio.h>
void main()
                         {1, 0, 0},
                         {1, 1, 1},
                         {0, 0, 1},
                         {1, 1, 1} };
 do {
         break;
     int w, h;
         break;
         printf("\n");
 } while (false);
 ippsFree(pBuffer);
 ippiFree(pSrc1);
 ippiFree(pSrc2);
 ippiFree(pDst);
Gennady_F_Intel
Kim,
please keep us informed of the performance results you will obtain.
Gennady
KIM__ILTAEK
Hi, Andrey Bakshaev
Thank your shared information. Your advice has been a great help.
Let me ask you one more question.
Actually I want to use ippiROISame option. But when ippiROISame is used ippiConvGetBufferSize is returning an error. If I change the code below from the code you guided above, it becomes a problem. Is there a solution?
	//const int out_width = 5;
	//const int out_height = 9;
	const int out_width = 3;
	const int out_height = 5;
	//IppEnum funCfgFull = (IppEnum)(ippAlgAuto | ippiROIFull | ippiNormNone);
	IppEnum funCfgFull = (IppEnum)(ippAlgAuto | ippiROISame | ippiNormNone);
