RGBToGray with cv::Mat
Dahan__Dor
Hi Guys,
i'm trying to use ipp to convert rgb image to grayscale one.
following code:
        gray_frame = Mat(color_frame.size().width, color_frame.size().height, CV_8UC1);
        IppiSize roi;
        roi.width = color_frame.size().width;
        roi.height = color_frame.size().height;
        Ipp8u* ippRGBPtr = (Ipp8u*)&color_frame.data[0]; // Get pointer to the data
        int ipprgbStep = color_frame.step; // get step value in bytes
        Ipp8u* ippGrayPtr = (Ipp8u*)&gray_frame.data[0]; // Get pointer to the data
        int ippGrayStep = gray_frame.step; // get step value in bytes
        ippiRGBToGray_8u_C3C1R(ippRGBPtr, ipprgbStep, ippGrayPtr, ippGrayStep, roi); // do the color conversion
the problem i'm facing is that the image i now fully procced,
when i cv::imshow(gray_frame) i see half of the image.
what can be the problem?
thank you!
Andrey_B_Intel
Hi Dahan Dor.
I've reproduced your issue.
Swap please width and height in this line
with
gray_frame = Mat(color_frame.size().height, color_frame.size().width, CV_8UC1)
