IPP Feature request
pdoege
I would like to see the YUV->YUV Join/Split support 3 plane 420.
Right now it only seems to support UV interleaved data.
The workaround is to scale the U,V planes and then use 4:2:2 functions.Not all that efficient.
Peter Doege
Vladimir_Dudnik
did you see these function in ippi.h file for IPP v4.0? It seems to be what you are looking for.
// Name: ippiJoin420_8u_P2C2R, ippiJoin420_Filter_8u_P2C2R
// Purpose: Convert from 420 plane image format to 2-channal pixel
// image format.
// Return:
// ippStsNoErr Ok
// ippStsNullPtrErr One or more pointers are NULL
// ippStsSizeErr if imgSize.width < 2 || imgSize.height < 2
// Arguments:
// pSrcY Pointer to the source image Y plane.
// srcYStepY The step for source image Y plane.
// pSrcUV Pointer to the source image UV plane.
// srcUVStep The step for source image UV plane.
// pDst The pointer to destination image
// dstStep The step for destination image
// roiSize Size of ROI should be multiple 2.
// layout the order of the slice processing with deinterlace filter.
// The following are allowed
// IPP_UPPER - the first slice.
// IPP_CENTER - the midlle slices.
// IPP_LOWER - the last slice.
// IPP_LOWER && IPP_UPPER && IPP_CENTER - the whole image.
// Notes:
// Sequence of bytes in the source image is( NV12 ):
// A format in which all Y(pSrcY) samples are found first in memory as an array of
// unsigned char with an even number of lines memory alignment),
// followed immediately by an array(pSrcUV) of unsigned char
// containing interleaved U and V samples (such that if addressed as a little-endian
// WORD type, U would be in the LSBs and V would be in the MSBs).
// This is the 4:2:0 pixel format.
// Sequence of bytes in the destination image is(YUY2):
// Y0U0Y1V0,Y2U1Y3V1,... This is the 4:2:2 pixel format.
// f. ippiJoin420_Filter_8u_P2C2R serves for processing the image on slice( height of slice
// should be multiple 16).
IPPAPI(IppStatus, ippiJoin420_8u_P2C2R,(const Ipp8u* pSrcY, int srcYStep,const Ipp8u* pSrcUV,
int srcUVStep, Ipp8u* pDst, int dstStep, IppiSize roiSize))
IPPAPI(IppStatus, ippiJoin420_Filter_8u_P2C2R,(const Ipp8u* pSrcY, int srcYStep,const Ipp8u* pSrcUV,
int srcUVStep, Ipp8u* pDst, int dstStep, IppiSize roiSize,int layout))
// Name: ippiSplit420_8u_P2P3R, ippiSplit420_Filter_8u_P2P3R
// Purpose: Convert from 420 plane image format to 3-channal plane
// image format.
// Return:
// ippStsNoErr Ok
// Arguments:
// pDst[3] It is three pointers to destination i mages
// dstStep[3] It is three steps for previous three images
// Notes:
// Sequence of bytes in the destination image is( YV12 ):
// the order of the pointers to destination images si Y V U.This is the 4:2:0 pixel format.
// f. ippiSplit420_Filter_8u_P2P3R serves for processing the image on slice( height of slice
IPPAPI(IppStatus, ippiSplit420_8u_P2P3R,(const Ipp8u* pSrcY, int srcYStep,const Ipp8u* pSrcUV,
int srcUVStep, Ipp8u* pDst[3], int dstStep[3], IppiSize roiSize))
IPPAPI(IppStatus, ippiSplit420_Filter_8u_P2P3R,(const Ipp8u* pSrcY, int srcYStep,const Ipp8u* pSrcUV,
int srcUVStep, Ipp8u* pDst[3], int dstStep[3], IppiSize roiSize,int layout))
Vladimir
pdoege
Hello -
Thanks for your response. I believe that I tried that function and received a stride error result. I will try again and get back to you.
Peter Doege
pdoege
Unfortunately, ippiJoin420_8u_p2c2R wants interleaved UV data and my data is not interleaved. I actually do have 3 planes. Y,U,V. The 422 functions allow 3 planes, but the 420 functions assume 2 planes. Weird, but that is how it is.
I would like to have 420 functions that allow me to pass in 3 planes.
Peter Doege
Vladimir_Dudnik
thanks, now I understand. So, please submit your request through technical support channel and we will revise it when planning the next version.
Vladimir
