6824 Discussions
IPP Library compatiblity with windows DDK 6001.18002
nyryder
I am trying to integrate the IPP libraries with my windows driver(WDK). Just for an example i have tried to use the ippGetLibVersion to get the version number, i created the TARGETTYPE=PROGRAM in the sources file in WINDDK, and set the library path in my sources , the program compiles successfully and builds the executable, But When i tried to run the program i get an error of" is not a valid win32 application". Are the IPP libraries compatible with WIN DDK?. I dont see any example in the document. I have attached my c code and sources file with this mail. Thanks for your inputs
nyryder
Quoting - nyryder
Updated the sources file but still sees the same problem "not a valid win32 application"
IPPROOT=C:ProjectINTELIPP6.0.1.070ia32
TARGETNAME=IPPCHECK
TARGETPATH=obj
TARGETTYPE=PROGRAM
USE_MSVCRT=1
IPP_INC_PATH=$(IPPROOT)include
IPP_LIB_PATH=$(IPPROOT)lib
TARGETLIBS=$(IPP_LIB_PATH)ippcorel.lib $(IPP_LIB_PATH)ippsemerged.lib
$(IPP_LIB_PATH)ippsmerged.lib
INCLUDES=$(IPP_INC_PATH);$(DDK_INC_PATH)
LINKER_FLAGS = $(LINKER_FLAGS) /map
UMTYPE=console
UMENTRY=main
SOURCES=ippchk.c
Vladimir_Dudnik
are you aware that IPP also provide sample package, where you will find an example of how to use IPP in kernel mode drivers (Windows and Linux supported, Mac OS might be supported in future)
Vladimir
