IPP PCA samples
Intel_C_Intel
Hi ,
I downloaded IPP evaluation version and installed on the RH9 host. I want to use IPPs for PXA processors using IPP_PCAwmmx. Version downloadedl_pca_wmmx_p_5_0_0006.
After installationI compiled a downloaded sample application for PCA. The IPP lib is not installed. It looks for a ippSPWMMXLNX50r.a under the lib/mvlce folder. But it does not have that folder installed and *.a file is not available.
Help me compile the sample codesr_aec
thanks
Ravi
Vladimir_Dudnik
Hi, could double check you installation. There should be lib/mvlcee folder with file ippSP_WMMX50LNX_r.a
Vladimir
