6847 Discussions
IPP Simple_render Example Failed to run in two separate process
dzhou_tac
IP simple_render example fails to display video for the second executing thread, if DirectX is selected as video render.
I checked the code, it seems the video display window is set to Windowed Mode with Cooperate Level. Any easy fix?
thanks,
david
PaulF_IntelCorp
Hello David,
I checked for some similar issues regarding your question and it appears that, based on reviewing those similar questions, multiple instances of the DirectX renderer are not supported in the IPP samples provided.
Paul
