Intel Samples
shinjite
I was wondering when you are going to update your samples - theres a lot of thread crashing code in your umc h264 decoder and encoder.
Also, on another note - There should be a ReleaseInternalBuffers Function so that it releases all buffered frames (GetFrame) so when I close it wont crash. Instead I have to get frame for 0.54 seconds until it unbuffers all frames then close...
This crash may not be noticable when doing numThreads = 1;
Overall just really curious when another sample update will come out :).
Ying_H_Intel
Quoting - shinjite
Hello shinjie,
We will release a new version (IPP 6.1 update 2)in themonth. Please note the website notification.You are welcomed to try it.
As I knew, there are several bugs fixed in the updaterelated tothe H.264 encoder and decoder. But not sure ifthey address your problem.You mentioned there are a lots of crashing code and may not be noticable when numThreads=1. Do you mean the sample codeathttp://software.intel.com/en-us/articles/getting-started-with-intel-ipp-unified-media-classes-sample/=>simpledecoder.cpp, it is using the numThreads=1.
//usedefaultparamter,threadingnumber=1
  • Params.m_pData=&DataIn;Params.lFlags=0;Params.numThreads=1;
  • The sample can work fine when numThreads=1 and will crash if we change the threads?Could you please provide more details about the crash(likeOS, IPP version,a piece of test bitstreamcan reproduce the crash would be helpfuletc)?
    Ying H.
