IPP and Embarcadero
aphesa
Hi all,
we are using Embarcadero C++ Builder 2010. I'd like to know if IPP is compatible with it (100%, partially, not at all).
I have read through the online documentation and it says "any C or C++ software" but many other intel products are limited to the Microsoft and Intel compilers. What about IPP?
We are occasionally also using Dev-Cpp.
Thank you.
Arnaud.
Vladimir_Dudnik
Arnaud,
although we did not test IPP with Embarcadero C++ Builder specifically, but because IPP provides sdtcall API libraries it should be compatible with anycompiler which support call of libraries with stdcall API.
Vladimir
aphesa
Ok, i'll give it a try. Thank you.
