IPP for PXA255 on WinCE
madmax2005
I'm porting an application which uses IPP library.
First, I 've adapted it for PXA270 processor on WINCE 5.0 and it's working.
Now, I'd like to port it for PXA255 on WINCE 4.2.
IPP 5.0 for PXA27X (pca_wmmx), is it compatible with PXA255 and WINCE4.2 ???
If yes, it's a good news.
If no, must I use IPP 4.2 and is it compatible with PXA255 ???
If no, must I use IPP for IPX. In this case, the interface is not compatible with IPP for PXA. For example, there isn't ippiDCT8x8Inv_Video_16s_C1I function.
Many thanks in advance for your help.
Maxime
Ying_S_Intel
Dear Customer,
For this case, you may use the IPP 4.1.2 that supports Intel PXA255.
Hope it helps.
Ying S
Intel Corp.
madmax2005
Hi Ying,
Thanks for your response.
I have only the IPP4.2.
Where could I find IPP4.1 because on the site, we can download only the latest version of IPP ???
Maxime.
Ying_S_Intel
If you have a valid account with Intel Premier Support you should find these updated download files under Intel IPP products:
1) Intel IPP for Windows*
2) Intel IPP for Linux*
3) Intel IPP Samples
4) Cryptography for Intel IPP.
Ying
