6818 Discussions
IPP not work on FreeBSD 7.2-RELEASE linux_base-fc4
nagual
Hi
#!/usr/local/bin/perl -w
use strict;
use vars qw($VERSION @ISA @EXPORT @EXPORT_OK);
require Exporter;
require DynaLoader;
require AutoLoader;
@ISA = qw(Exporter DynaLoader);
use Inline (C => Config =>
# DIRECTORY => './inline_dir',
# LIBS => '-lfoo',
# INC => '-I/foo/include',
# PREFIX => 'XXX_',
#DISABLE => 'AUTONAME',
FORCE_BUILD => 0,
CLEAN_AFTER_BUILD => 0,
WARNINGS => 1,
LIBS => '-L/usr/work/fastcgi/ -L/usr/compat/linux/lib -libdl -libc -libm',
LIBS => '-L/usr/work/fastcgi/',
LIBS => '-L/usr/compat/linux/lib/',
MYEXTLIB => q[/usr/work/fastcgi/libippcore.so.6.0 /usr/work/fastcgi/libiomp5.so /usr/compat/linux/lib/libc-2.3.6.so /usr/compat/linux/lib/libdl-2.3.6.so /usr/compat/linux/lib/libm-2.3.6.so],
use Inline C => <<'END';
int poisk ( char* x, int m , char* y, int n) {
int (*p)(const Ipp8u* pSrc, int len, const Ipp8u* pFind, int lenFind, int *pIndex)=NULL;
Ipp8u* pSrc; int len; Ipp8u* pFind; int lenFind; int *pIndex;
void *handle;
handle= dlopen("/usr/work/fastcgi/libippchv8.so.6.0");
if (!handle) {
fputs (dlerror(), stderr);
exit(1);
p=dlsym( handle ,"ippsFind_16u");
char *err=dlerror();
if(err!=NULL) {
fputs(err,stderr);
exit(1);
char a[] = "xyzwtwretwertwertwertwertwrtw";
char aa[] = "xyz";
int t = sizeof(a);
int tt = sizeof(aa);
pSrc=a;
len=t;
pFind=aa;
lenFind=tt;
pIndex=-1;
(*p)(pSrc ,len, pFind, lenFind , pIndex);
//return pIndex;
# ls -l
total 2980
-rw-r--r-- 1 root max 120 Jun 15 01:14 .packlist
-r--r--r-- 1 root max 0 Jun 15 00:58 find051_pl.bs
-rw-r--r-- 1 root max 563 Jun 15 01:14 find051_pl.inl
-r-xr-xr-x 1 root max 8131 Jun 15 01:14 find051_pl.so
-rwxr-xr-x 1 root wheel 121236 Jun 14 13:56 ld-linux.so.2
-rwxr-xr-x 1 root wheel 1434044 Jun 14 13:55 libc.so.6
-rwxr-xr-x 1 root max 14424 Jun 14 20:07 libdl.so.2
-rwxr-xr-x 1 root max 412693 Jun 14 20:41 libiomp5.so
-rwxr-xr-x 1 root max 598070 Jun 14 14:12 libippchv8.so.6.0
-rwxr-xr-x 1 root max 50345 Jun 14 20:02 libippcore.so.6.0
-rwxr-xr-x 1 root wheel 203176 Jun 14 13:55 libm.so.6
-rwxr-xr-x 1 root wheel 95308 Jun 14 13:55 libpthread.so.0
libippcore.so.6.0 => /usr/work/fastcgi/_Inline/lib/auto/find051_pl//libippcore.so.6.0 (0x282db000)
libdl.so.2 => /usr/work/fastcgi/_Inline/lib/auto/find051_pl//libdl.so.2 (0x282e5000)
libiomp5.so => /usr/work/fastcgi/_Inline/lib/auto/find051_pl//libiomp5.so (0x28b8d000)
libm.so.6 => /usr/work/fastcgi/_Inline/lib/auto/find051_pl//libm.so.6 (0x2db00000)
libc.so.6 => /usr/local/lib/compat/libc.so.6 (0x2db26000)
ld-linux.so.2 (0x2dc0d000)
libpthread.so.0 => /usr/work/fastcgi/_Inline/lib/auto/find051_pl//libpthread.so.0 (0x282e9000)
End stop ...
Vladimir_Dudnik
Youshould be able touse IPP not threaded static libraries on FreeBSD systems.
Vladimir
