number of frames
mikl_la
hi,
how can i get the total number of frames of a video?
regards,
michael
Vladimir_Dudnik
From where do you want to get total number of video? What IPP component you are using?
Vladimir
mikl_la
Vladimir
i'm using unified media classes to write a video-decoder/player. so i'd like to show the totalnumber of frames,e.g. of a mpeg2-video, in the gui.
michael
shyaki
Quoting - mikl_la
michael
Unless your file wrapper contains this number, you have to partially decode the stream I think.
iambaeba1
Quoting - shyaki
You can retreive video/audio/etc information using MediaInfo.
The sample code is followed..
[cpp]#include
#include "MediaInfoDLL.h"
using namespace MediaInfoLib;
int GetMovieInfo(
	char*					_inp08FilePath,
	MediaInfo				MI;
	char					np08Buf[2048]
	int						n32Result,n32FrameCount;
	n32Result = MI.Open(_T(_inp08FilePath));
		if (n32Result == 0)
			return -1;
	 * Retrieve general movie information
	sprintf(np08Buf,"%s", MI.Get(Stream_General, 0, _T("FileName"        ),	Info_Text, Info_Name).c_str());
	sprintf(np08Cuf,"%s", MI.Get(Stream_General, 0, _T("FileExtension"   ),	Info_Text, Info_Name).c_str());
	sprintf(np08Buf,"%s", MI.Get(Stream_General, 0, _T("FileSize"        ), Info_Text, Info_Name).c_str());
	sprintf(np08Buf,"%s", MI.Get(Stream_General, 0, _T("Format/String"   ),	Info_Text, Info_Name).c_str());
	sprintf(np08Buf,"%s", MI.Get(Stream_General, 0, _T("Format/Family"   ),	Info_Text, Info_Name).c_str());
	sprintf(np08Buf,"%s", MI.Get(Stream_General, 0, _T("PlayTime/String3"), Info_Text, Info_Name).c_str());
	sprintf(np08Buf,"%s", MI.Get(Stream_General, 0, _T("Duration"        ), Info_Text, Info_Name).c_str());
	sprintf(np08Buf,"%s", MI.Get(Stream_General, 0, _T("BitRate"         ), Info_Text, Info_Name).c_str());
	sprintf(np08Buf,"%s", MI.Get(Stream_General, 0, _T("OveralBitRate"   ),	Info_Text, Info_Name).c_str());
	sprintf(np08Buf,"%s", MI.Get(Stream_General, 0, _T("VideoCount"      ), Info_Text, Info_Name).c_str());
	sprintf(np08Buf,"%s", MI.Get(Stream_General, 0, _T("AudioCount"      ), Info_Text, Info_Name).c_str());
	sprintf(np08Buf,"%s", MI.Get(Stream_General, 0, _T("TextCount"       ),	Info_Text, Info_Name).c_str());
	 * Retrieve video information
	sprintf(np08Buf,"%s", MI.Get(Stream_Video, 0, _T("Codec/String"             ), Info_Text, Info_Name).c_str());
	sprintf(np08Buf,"%s", MI.Get(Stream_Video, 0, _T("Codec/Family"             ), Info_Text, Info_Name).c_str());
	sprintf(np08Buf,"%s", MI.Get(Stream_Video, 0, _T("Width"                    ), Info_Text, Info_Name).c_str());
	sprintf(np08Buf,"%s", MI.Get(Stream_Video, 0, _T("Height"                   ), Info_Text, Info_Name).c_str());
	sprintf(np08Buf,"%s", MI.Get(Stream_Video, 0, _T("BitRate"                  ), Info_Text, Info_Name).c_str());
	sprintf(np08Buf,"%s", MI.Get(Stream_Video, 0, _T("BitRate_Nominal"          ), Info_Text, Info_Name).c_str());
	sprintf(np08Buf,"%s", MI.Get(Stream_Video, 0, _T("BitRate_Mode"             ), Info_Text, Info_Name).c_str());
	sprintf(np08Buf,"%s", MI.Get(Stream_Video, 0, _T("DisplayAspectRatio"       ), Info_Text, Info_Name).c_str());
    sprintf(np08Buf,"%s", MI.Get(Stream_Video, 0, _T("DisplayAspectRatio/String"), Info_Text, Info_Name).c_str());
	sprintf(np08Buf,"%s", MI.Get(Stream_Video, 0, _T("FrameRate"                ), Info_Text, Info_Name).c_str());
	sprintf(np08Buf,"%s", MI.Get(Stream_Video, 0, _T("Interlacement/String"     ), Info_Text, Info_Name).c_str());
	sprintf(np08Buf,"%s", MI.Get(Stream_Video, 0, _T("FrameCount"               ), Info_Text, Info_Name).c_str());
	n32FrameCount = atoi(np08Buf);
	 * Retrieve audio information
	sprintf(np08Buf,"%s", MI.Get(Stream_Audio, 0, _T("Codec"             ), Info_Text, Info_Name).c_str());
	sprintf(np08Buf,"%s", MI.Get(Stream_Audio, 0, _T("Codec/String"      ), Info_Text, Info_Name).c_str());
	sprintf(np08Buf,"%s", MI.Get(Stream_Audio, 0, _T("BitRate"           ), Info_Text, Info_Name).c_str());
	sprintf(np08Buf,"%s", MI.Get(Stream_Audio, 0, _T("BitRate_Mode"      ), Info_Text, Info_Name).c_str());
	sprintf(np08Buf,"%s", MI.Get(Stream_Audio, 0, _T("Channel(s)"        ),	Info_Text, Info_Name).c_str());
	sprintf(np08Buf,"%s", MI.Get(Stream_Audio, 0, _T("SamplingRate"      ),	Info_Text, Info_Name).c_str());
	MI.Close();
	return 1;
[/cpp]
