6825 Discussions
IPP unable to patch lz4-1.9.3 using lz4-1.9.3.patch.bin - Windows
arun-kv
Hi, I'm unable to patch lz4-1.9.3 using lz4-1.9.3.patch.bin, I'm getting below conflicts while trying to patch.
C:\Users\akv\Desktop\work\lz4-1.9.3>"c:\Program Files (x86)\GnuWin32\bin\patch.exe" -p1 --binary < c:\Users\akv\Desktop\lz4-1.9.3.patch.bin
(Stripping trailing CRs from patch.)
patching file build/cmake/CMakeLists.txt
patching file build/VS2010/datagen/datagen.vcxproj
Hunk #1 FAILED at 1.
Hunk #2 FAILED at 17.
Hunk #3 FAILED at 47.
Hunk #4 FAILED at 166.
Hunk #5 FAILED at 202.
Hunk #6 FAILED at 242.
Hunk #7 FAILED at 286.
7 out of 7 hunks FAILED -- saving rejects to file build/VS2010/datagen/datagen.vcxproj.rej
patching file build/VS2010/frametest/frametest.vcxproj
7 out of 7 hunks FAILED -- saving rejects to file build/VS2010/frametest/frametest.vcxproj.rej
patching file build/VS2010/fullbench/fullbench.vcxproj
7 out of 7 hunks FAILED -- saving rejects to file build/VS2010/fullbench/fullbench.vcxproj.rej
patching file build/VS2010/fullbench-dll/fullbench-dll.vcxproj
Hunk #4 FAILED at 168.
Hunk #5 FAILED at 206.
Hunk #6 FAILED at 248.
Hunk #7 FAILED at 294.
7 out of 7 hunks FAILED -- saving rejects to file build/VS2010/fullbench-dll/fullbench-dll.vcxproj.rej
patching file build/VS2010/fuzzer/fuzzer.vcxproj
7 out of 7 hunks FAILED -- saving rejects to file build/VS2010/fuzzer/fuzzer.vcxproj.rej
patching file build/VS2010/liblz4/liblz4.vcxproj
Hunk #4 FAILED at 173.
Hunk #5 FAILED at 211.
Hunk #6 FAILED at 253.
Hunk #7 FAILED at 299.
7 out of 7 hunks FAILED -- saving rejects to file build/VS2010/liblz4/liblz4.vcxproj.rej
patching file build/VS2010/liblz4-dll/liblz4-dll.vcxproj
Hunk #3 FAILED at 48.
Hunk #4 FAILED at 174.
Hunk #5 FAILED at 208.
Hunk #6 FAILED at 246.
Hunk #7 FAILED at 288.
7 out of 7 hunks FAILED -- saving rejects to file build/VS2010/liblz4-dll/liblz4-dll.vcxproj.rej
patching file build/VS2010/lz4/lz4.vcxproj
Hunk #4 FAILED at 167.
Hunk #5 FAILED at 204.
Hunk #6 FAILED at 245.
Hunk #7 FAILED at 290.
7 out of 7 hunks FAILED -- saving rejects to file build/VS2010/lz4/lz4.vcxproj.rej
patching file build/VS2010/lz4.sln
Hunk #1 FAILED at 21.
1 out of 1 hunk FAILED -- saving rejects to file build/VS2010/lz4.sln.rej
patching file build/VS2017/datagen/datagen.vcxproj
Hunk #4 FAILED at 73.
Hunk #5 FAILED at 87.
Hunk #6 FAILED at 174.
Hunk #7 FAILED at 210.
Hunk #8 FAILED at 250.
Hunk #9 FAILED at 294.
9 out of 9 hunks FAILED -- saving rejects to file build/VS2017/datagen/datagen.vcxproj.rej
patching file build/VS2017/frametest/frametest.vcxproj
9 out of 9 hunks FAILED -- saving rejects to file build/VS2017/frametest/frametest.vcxproj.rej
patching file build/VS2017/fullbench/fullbench.vcxproj
9 out of 9 hunks FAILED -- saving rejects to file build/VS2017/fullbench/fullbench.vcxproj.rej
patching file build/VS2017/fullbench-dll/fullbench-dll.vcxproj
Hunk #6 FAILED at 176.
Hunk #7 FAILED at 214.
Hunk #8 FAILED at 256.
Hunk #9 FAILED at 302.
9 out of 9 hunks FAILED -- saving rejects to file build/VS2017/fullbench-dll/fullbench-dll.vcxproj.rej
patching file build/VS2017/fuzzer/fuzzer.vcxproj
9 out of 9 hunks FAILED -- saving rejects to file build/VS2017/fuzzer/fuzzer.vcxproj.rej
patching file build/VS2017/liblz4/liblz4.vcxproj
Hunk #6 FAILED at 181.
Hunk #7 FAILED at 219.
Hunk #8 FAILED at 261.
Hunk #9 FAILED at 307.
9 out of 9 hunks FAILED -- saving rejects to file build/VS2017/liblz4/liblz4.vcxproj.rej
patching file build/VS2017/liblz4-dll/liblz4-dll.vcxproj
Hunk #3 FAILED at 49.
Hunk #4 FAILED at 74.
Hunk #5 FAILED at 88.
Hunk #6 FAILED at 182.
Hunk #7 FAILED at 216.
Hunk #8 FAILED at 254.
Hunk #9 FAILED at 296.
9 out of 9 hunks FAILED -- saving rejects to file build/VS2017/liblz4-dll/liblz4-dll.vcxproj.rej
patching file build/VS2017/lz4/lz4.vcxproj
Hunk #2 FAILED at 47.
Hunk #3 FAILED at 77.
Hunk #4 FAILED at 154.
Hunk #5 FAILED at 181.
Hunk #6 FAILED at 218.
Hunk #7 FAILED at 255.
7 out of 7 hunks FAILED -- saving rejects to file build/VS2017/lz4/lz4.vcxproj.rej
patching file build/VS2017/lz4.sln
Hunk #1 FAILED at 23.
1 out of 1 hunk FAILED -- saving rejects to file build/VS2017/lz4.sln.rej
patching file examples/Makefile
patching file lib/dll/example/Makefile
patching file lib/lz4.c
patching file lib/Makefile
patching file ossfuzz/Makefile
patching file programs/Makefile
patching file tests/Makefile
VidyalathaB_Intel
We are working on it internally. we will get back to you soon.
Vidya.
Abhinav_S_Intel
Hi Arun,
Can you share your open source LZ4 downloaded link and steps you performed to unarchive the package?
As a workaround, please use the IPP LZ4 patch without the "--binary" option.
Our early investigation shows this issue is due to different end-of-lines in patch file and patched source code files.
Abhinav
arun-kv
@VidyalathaB_Intel  @Abhinav_S_Intel  Thank you for the reply.
Without --binary option  I'm able to patch lz4.
Source code link : https://github.com/lz4/lz4/releases/tag/v1.9.3 ( Source code.zip)
I have used 7-zip to unarchive the zip file.
Patch command used: C:\Users\akv\Desktop\work\lz4-1.9.3>"c:\Program Files (x86)\GnuWin32\bin\patch.exe" -p1 --binary < c:\Users\akv\Desktop\lz4-1.9.3.patch.bin
Now I'm getting compilation issue like below, "cannot open include file 'lz4.h'", I'm using Visual studio 2019
same error was given by "programs/lz4io.c" also, that I resolved by adding "lz4-1.9.3/lib" to "Additional Include Directories"
Arun.
Abhinav_S_Intel
Hi Arun,
First of all please configure Visual Studio to link with IPP. Refer to this article, if you've chosen automatic integration or else you have to manually configure your project:
https://software.intel.com/content/www/us/en/develop/documentation/dev-guide-ipp-for-oneapi/top/programming-with-intel-integrated-performance-primitives-in-the-microsoft-visual-studio-ide/configuring-the-microsoft-visual-studio-ide-to-link-with-intel-ipp.html
This seems more like an Visual Studio configuration/upgrade issue.
I am also using Visual Studio 2019 and upgraded the solution from 2017 which is available at lz4-1.9.3\build\VS2017\lz.sln
Without applying IPP patch, I was able to compile 32 bit binaries without any issues but not 64 bit. I am getting similar errors like you reported. After applying the IPP patch the situation still remains the same.
The next test which I performed was to use the 2010 solution and upgraded to latest SDK supported by Visual Studio 2019. The solution is available at lz4-1.9.3\build\VS2010\lz.sln
With and without IPP patch, I was able to compile 32 and 64 binaries. This issue needs more investigation on why the compilation failed with 2017 solution.
Please let us know about your test results.
Abhinav
arun-kv
@Abhinav_S_Intel  VS2010\lz.sln works for me.
Thank you so much for the help.
