IPPISet is slower than memset & IPPSSET
murali_523
  We tried IPPISET roi based method to set the set of portions in the image 0.
  But this is slower than memset [on entire image to 0]
  We have tried the IPPSSET and found it is more faster than memset and IPPISET.
  Is the ROI based method usually slower than non-ROI based method like IPPSSET.
  Actually we thought since we were doing selective regions in image to reset to zero using IPPISET ,it should be faster than memset and IPPSET   performed on entire image.
   But when we profile we found the IPPISET[called four time on four different small region on image] is taking more time than IPPSSET and memset.
  Can you please explain why/how this can happen?
  We were using IPP 7.0 version.
 Thanks & Regards,
Murali
SergeyKostrov
Valued Contributor II
Some time in 2012 I've evaluated performance of ippsSet_8u and ippiSet_8u_C1R on an image with size 34207 x 34207. However, it was for the entire image without using ROI(s). >>...Is the ROI based method usually slower than non-ROI based method like IPPSSET... I wouldn't make any statements until some tests are completed. Could you post your test-case? What ippsSet_xxx function did you use? >>...it should be faster than memset and IPPSET performed on entire image... Please see my comment above.
SergeyKostrov
Update: >>...What ippsSet_xxx function did you use? What ippiSet_xxx and ippsSet_xxx functions did you use?
murali_523
For IPPsSet i had used ippsSet_8u
For IPPISet i had used ippiSet_8u_AC4
The image is a 32-bit color image and we need to set the four corner ROI's to '0' value
SergeyKostrov
>>...The image is a 32-bit color image and we need to set the four corner ROI's to '0' value... Could you provide more detailed details, I would say so?
Igor_A_Intel
AC4 should be slower by definition - AC4 memory layer means 4 channels with A channel - A channel in IPP is not touched by definition. To set all 4 channels to 0 you should use ippiSet_8u_C4R.
Regards, Igor
