6831 Discussions
IPPs deflate goes into infinite loop for file size >= 2GB
mickaelpic
Hi, I am compressing a file of size 2GB using deflate with Z_NO_FLUSH.
When deflate has processed 2GB (minus 2 bytes) it will go into infinite loop.
Because the avail_in is always equal 2
I have tried with any file size >= 2GB and the problem always occurs.
Any file size < 2GB is working perfectly.
I am using the following code:
#define bufferSize 65536 // 64KB
#define aesBlkSize 32
inBuffer = (unsigned char*)ippMalloc(bufferSize);
if(inBuffer == NULL)
printf("Failed to initialize inBuffer ");
return -1;
outBuffer = (unsigned char*)ippMalloc(bufferSize);
if(outBuffer == NULL)
printf("Failed to initialize outBuffer ");
return -1;
stream.next_in = inBuffer;
stream.next_out = outBuffer;
stream.avail_out = bufferSize;
stream.avail_in = 0;
int toWrite = 0;
do
len = (unsigned long)fread((char*)inBuffer, 1, bufferSize, fin);
stream.avail_in = len;
if(len > 0)
do
//LOOPING INFINITLY HERE
err = deflate(&stream, Z_NO_FLUSH);
if(err == Z_OK)
if(stream.avail_out < bufferSize)
toWrite = bufferSize - stream.avail_out;
// write the buffer
if(fwrite((char*)outBuffer, 1, toWrite, fout) != toWrite)
printf("Failed to write to file ");
return -1;
else
if(Check_Error(err, "deflate") == -1)
return -1;
while(stream.avail_in != 0);
while(len != 0);
do
err = deflate(&stream, Z_FINISH);
if(err == Z_OK || err == Z_STREAM_END)
// write the buffer
if(fwrite((char*)outBuffer, 1, stream.total_out, fout) != stream.total_out)
return -1;
else
// Error
if(Check_Error(err, "Z_FINISH") == -1)
return -1;
while(err != Z_STREAM_END);
err = deflateEnd(&stream);
if(Check_Error(err, "deflateEnd") == -1)
return -1;
Vladimir_Dudnik
Please specify IPP version, operating system and host processor architecture for the system where you met that issue.
Vladimir
VipinKumar_E_Intel
This has been fixed in IPP 6.0 beta.
