Image Geometry Transform - rotation direction
Mike4
Hi all !
I have a problem using the ippiRotate_xxx methods.
with 8u_C1R and 8u_C3R the direction is clockwise
with 8u_C4R the direction is counterclockwise
I use the IPP 7.01 library.
Is it a normal behavior ?
Mike
Yuri_Tikhomirov__Int
HelloMike,
Could you please provide a sample code with more information about your problem?
What is interpolation method? Whatis image size? Angle?
Beg
Chao_Y_Intel
Hi Beg,
You can also run the IPP ippiDemo.exe at Intel\IPP\6.1.6.056\ia32\demo\, and see if this is a code error, or a bug related with IPP.
Chao
Please take a look at thepictures obtained by using ippiDemo application.
Rotation of (30) and (360-30) degrees.
What is wrong ?
Beg
Mike4
Hi all,
may be I made a mistake but I used the same code with ipp 3.0 and I have never had any error.
here is my code :
double dAngle = 45;
double dBounds[2][2];
IppiRect rect = {0, 0, 640, 480};
IppStatus status = ippiGetRotateBound(rect, dBounds, dAngle, 0, 0);
IppiRect rectOutput = {0, 0,dBounds[1][0] - dBounds[0][0],dBounds[1][1] - dBounds[0][1]};
IppiSize sizeInput = {rect.width, rect.height};
status = ippiRotate_8u_C3R(pInputBuffer, sizeInput, iStrideIn, rect,
pOutputBuffer, iStrideOut, rectOutput,
dAngle, -dBounds[0][0], -dBounds[0][1], IPPI_INTER_LINEAR);
status = ippiRotate_8u_C4R(
dAngle,-dBounds[0][0], -dBounds[0][1], IPPI_INTER_LINEAR);
(the pInputBuffer for the 2 above versions are respectively in 24bits and 32bits)
8u_C3R and 8u_C1R rotate in clockwise direction and 8u_C4R in counterclockwise direction
I have the same behavior between 8u_C4R and 8u_AC4R.
Later, if necessary, I will put a test program with full c++ source code. For the moment I haven't the time to do it. To patch the problem I invert the angle in 8 and 24 bits.
I made the tests with ippiDemo, I have the same rotation direction with 24 et 32bits pictures but in clockwise direction (the inverse as noticed in documentation).
