Image resizing question
abraidwood
I'm resizing large images (>10000x10000, rgb or cmyk) using the ippiResize functions.
Am I correct in thinking that the functions require a whole image to be loaded into memory? (not neseccarily a problem as memory is cheap)
Also, are there some sizes & scaling which work best? eg I know there are optimal ways of scaling to 50%, 33%, does the ippiResize also benefit at these scalings?
I've been musing about loading either a few scanlines at a time, or breaking the images into tiles - would a 10x10 set of 1024x1024 image tiles scale faster?
thanks,
Alistair
Vladimir_Dudnik
Hi Alistair,
I recommend you to take a look on our sample which demonstrate how to work with tiled images, so you can breakhuge images into tiles and work with tiles. Please, download "w_ipp-sample-image_b_5.0.006.zip" file, you can find in this archive image-tiling sample
Vladimir
