Install on Gentoo??
chad_ata
Hi all,
I'm trying to install IPP on Gentoo. I emerged the RPM tools and ran the install script, but I got the following error:
error: Failed dependencies:
/bin/sh is needed by intel-ipp_common_ia32-5.1p-16
I have sh and it's in the /bin directory. So what's the problem??
Please help! I'd like to figure this out before my trial license expires =]
Chad
Vladimir_Dudnik
Hello Chad,
I remember there was a question about installation of IPP on Gentoo Linux. Could you please check suggestions we provided for that case (not sure it work, we do not support Gentoo Linux, so we did not test it)
Can't install in Gentoo box
Vladimir
clemens_rabe
Hello Chad,
since Gentoo is not based on rpms it has some difficulties with the dependencies. Simply use the --nodeps option for installation without dependency checking. On my system the commands are:
rpm -i --nodeps intel-ipp_common_ia32*.rpm
rpm -i --nodeps intel-ipp_ia32*.rpm
After that IPP can be found in the /opt/intel/ directory.
Clemens
chad_ata
Awesome. The rpms extracted. Thanks Clemens!
