Installation Error
chitra
During installation of l_ipp_ia32_p_6.0.1.071 we are getting the following error.
ERROR: This script installs Intel Performance Libraries and related products and should be called from general insall script. Exiting...
how to recover from this error?
Vladimir_Dudnik
could you please provide more complete info on your issue? What you actually trying to do? Whatis your platform/system configuration? Did you follow steps described in IPP documentation?
Vladimir
chitra
Quoting - vdudnik
could you please provide more complete info on your issue? What you actually trying to do? What is your platform/system configuration? Did you follow steps described in IPP documentation?
Vladimir
actually we are installing IPP in linux(fedora 9) environment. We successfully unzipped the tar file containing the ipp package by referring the IPP install guide.After that while running the command ./install.sh we got the error
ERROR: This script installs Intel Performance Libraries and related products and should be called from general install script. Exiting...
Nikolay_L_Intel
The package structure is (this is 6.0 IA32 example)
l_ipp_ia32_p_6.0.1.072/
install.sh (this file should be called for instalation)
cd_eject.sh
some text files (EULA, RN etc)
pset/
install.sh (internal install.sh)
It looks you are trying to start internal script. Could you start the proper one?
Thank you,
- Nikolay
