6847 Discussions
ipp 6.0 : RSA Encryption problem: ippsRSAGenerate crash
ndehoumon
ippsRSAGenerate keeps crashing. What's the problem with that code:
-static const Ipp32u dataE[] = {65537};
static const int keyLen = 2048;
primeLen_ = keyLen/2;
//pseudo-random engine
int rngSize;
ippsPRNGGetSize(&rngSize);
IppsPRNGState* pRNG = (IppsPRNGState*)ippsMalloc_8u(rngSize);
int MaxSeedBitsize=512;
ippsPRNGInit(MaxSeedBitsize, pRNG);
// Give entropy to the PRNG
BigNum b(data32Len);
b.Randomize();
status=ippsPRNGSetSeed(b.GetBN(), pRNG);
BigNum publicExponent(sizeof(dataE)/sizeof(dataE[0]));
publicExponent.Set(1,dataE); // calls ippsSet_BN
ippsRSAGenerate(
publicExponent.GetBN(),
keyLen_,
primeLen_,
gen_t(primeLen_),
pRSADecKey_,
ippsPRNGen,
pRNG
with :
int gen_t(int kp)
int t;
t = 27;
if(kp>150) t = 18;
if(kp>200) t = 15;
if(kp>250) t = 12;
if(kp>300) t = 9;
if(kp>350) t = 8;
if(kp>400) t = 7;
if(kp>450) t = 6;
return t;
Any suggestions will be very helpful Thanks.
Vladimir_Dudnik
our expert recommend you to try something like this:
[cpp]int gen_t(int kp)
int t;
t = 27;
if(kp>150) t = 18;
if(kp>200) t = 15;
if(kp>250) t = 12;
if(kp>300) t = 9;
if(kp>350) t = 8;
if(kp>400) t = 7;
if(kp>450) t = 6;
return t;
[/cpp]
Vladimir
Vladimir_Dudnik
The code you provide does ot compile. I would recommend you to carefully check parameters you use for IPP function call (please also refer to IPP documentation to see if any limitations have to be considered)
Vladimir
ndehoumon
Quoting - vdudnik
Vladimir
Hi ,
Thanks for your reply. The code does actually compile. But I did not want to paste all parts in this thread. So I try to replicate a kind of pseudo-code for it.
Anyway thanks, I fixed the problem.
Now my problem with ippsRSAGenerate is the t=nTrials Security parameter specified for the Miller-Rabin probable primality . When I use nTrials values derived from the Miller-Rabin pure theory , the program takes too much time to compute. It just to much calculations.
I'm using 2048-bit and 3072-bit keys. Do you have any suggestions ( tradoffs ) about nTrials values ?
Vladimir_Dudnik
int t;
t = 27;
if(kp>150) t = 18;
if(kp>200) t = 15;
if(kp>250) t = 12;
if(kp>300) t = 9;
if(kp>350) t = 8;
if(kp>400) t = 7;
if(kp>450) t = 6;
return t;
[/cpp]
Vladimir
