Installing redistributable
Graham
How do I include the IPP redistributable in my application's installer under VS2005?
If I just include the redist files the generated installer runs IPP install which then fails becuase nesting msi packages in not allowed. I getthis error.
"another installation is already in progress"
This is more a MS issue but other devlopers must have a solution that works with IPP.
Please help.
grant-keinzley
Quoting - Graham
Please help.
grant-keinzley
Quoting - Graham
Please help.
Try using Installshiel
http://www.acresso.com/products/is/installshield-overview.htm
I had a similar problem with VS2005 and found that Installshield successfully packaged all of the required files into a single installer from which I could edit which parts were to be installed in which order and ask the installer to wait until one install was complete before initiating the next.
Worked for me :)
