6812 Discussions
Intel Corp - Extension - 32.0.101.6127, Install error
Davidco
install update error again, still. It is : Intel Corp - Extension - 32.0.101.6127, Install error
Above  I was asked to choose a board. None of the suggestions fit my problem which I have had now going on two weeks.  I get : [Intel Corp - Extension - 32.0.101.6127, Install error ] . I have reinstalled windows 11 Home several times and everything looks good and works fine. Then if I try to do a Windows Update I get this error every time: Intel Corp - Extension - 32.0.101.6127, Install error.
I had Microsoft look at it one time and they said they would do a W11 International install. They did, but I lost all connections with the on restart. It worked OK for a day or two then when there was an automatic update (windows defender I think) it comes up with this error:  Update Failed. Intel Corp - Extension - 32.0.101.6127, Install error. I have put the problem up on this forum several times, and all I get is other people listing other problems.
Intel: have you got anyone who might have an idea.
The location posted above was just something I put down to be able to post this in the first place.
Ruqiu_C_Intel
Hello, Here is Intel® Integrated Performance Primitives software product community support channel. For your support request about Windows 11 update issue, we recommend you contact to Windows support Channel directly for achieving right support. Thank you for your understanding.
