Intel IPP PCA RGB Image Subtraction
gargankit28
I am developing a motion tracking application on an IPAQ H3970 with Windows CE. The camera that I am using for the application is LifeView FlyCAM-CF (350k).
When I subtract one RGB image from another using the ippiSub_8u_C3RSfs function, the resultant image is divided into 3. That is I can see the same subtracted image three times in the same video frame. Even when I save the resultant image as a bitmap file, it still shows as three.
Below is a snippet of my code. Please suggest a way to rectify this.
Thank you.
Ankit Garg
//Global variables
intg_prexsize=160;
intg_preysize=120;
intg_Capxsize=320;
intg_Capysize=240;
//Structure Definition Used
struct RGB_Struct
short width;
short height;
UINT8 *rgb;
//The function below takes two consecutive captures from the video and subtracts them
RGB_Struct *RGB1Temp, *RGB2Temp, *RGB3Temp;
RGB_Struct *g_pRGB2Out, *g_pRGB2Temp, *g_pRGB1Out, *g_pRGB1Temp;
unsigned char *pRGB1Temp, *pg_pRGB1Temp, *pRGB2Temp, *pg_pRGB2Temp;
SetCursor(LoadCursor(NULL, IDC_WAIT));
PreviewStop(hWnd);
g_pRGB1Out = (RGB_Struct *) AllocFileRGB(g_Capxsize, g_Capysize);
g_pRGB1Temp = (RGB_Struct *) AllocFileRGB( g_Capysize,g_Capxsize);
PlaySound(L"\Program Files\FlyCAM-CF Tools\CAMERA.WAV", NULL, SND_SYNC);
Capture_A_Frame((unsigned char *)g_pRGB1Out->rgb, &dSize);
ShowRGB(hWnd, g_pRGB1Out);
Sleep(1000);
pRGB1Temp=RGB1Temp->rgb;
for(y=g_Capxsize-1;y>=0;y--)
pg_pRGB1Temp=g_pRGB1Temp->rgb+y*g_Capysize*3;
for(x=0;x{
*pRGB1Temp++=*pg_pRGB1Temp++;
const Ipp8u *pSrc1 = (Ipp8u *)(g_pRGB1Out->rgb);
int src1Step = 720;
IppiSize roiSize = {240, 320};
SetCursor(NULL);
PreviewStart2(hWnd);
PreviewStop(hWnd);
g_pRGB2Out = (RGB_Struct *) AllocFileRGB(g_Capxsize, g_Capysize);
g_pRGB2Temp = (RGB_Struct *) AllocFileRGB( g_Capysize,g_Capxsize);
RGB3Temp = (RGB_Struct *) AllocFileRGB( g_Capysize,g_Capxsize);
Capture_A_Frame((unsigned char *)g_pRGB2Out->rgb, &dSize);
pRGB2Temp=RGB2Temp->rgb;
pg_pRGB2Temp=g_pRGB2Temp->rgb+y*g_Capysize*3;
for(x=0;x{
*pRGB2Temp++=*pg_pRGB2Temp++;
ShowRGB(hWnd, g_pRGB2Out);
Sleep(2000);
< DIV>
const Ipp8u *pSrc2 = (const Ipp8u*)(g_pRGB2Out->rgb);
//Ipp8u *pDst;
Ipp8u *pDst = (Ipp8u*)(RGB3Temp->rgb);
int src2Step = 720;
int dstStep = 720;
int scaleFactor = 1;
// Subtracts the 2 images here
ippiSub_8u_C3RSfs(pSrc1, src1Step, pSrc2, src2Step, pDst, dstStep, roiSize, scaleFactor);
// The subtracted image is displayed below as 3 copies in a frame
ShowRGB(hWnd, RGB3Temp);
Sleep(5000);
SetCursor(NULL);
FreeFileRGB(RGB1Temp);
FreeFileRGB(RGB2Temp);
FreeFileRGB(RGB3Temp);
FreeFileRGB(g_pRGB1Out);
FreeFileRGB(g_pRGB1Temp);
FreeFileRGB(g_pRGB2Out);
FreeFileRGB(g_pRGB2Temp);
PreviewStart(hWnd);
// Displays the image to the screen
BOOL ShowRGB (HWND hWnd, RGB_Struct *pRGB)
HDC hDC, hDCMem;
HGDIOBJ hOldObject;
HBITMAP hBitmap;
if (!pRGB->rgb || pRGB->width<=0 || pRGB->height<=0)
return FALSE;
if ( (g_prexsize==160) && (g_preysize==120) )
// o Device Context
if (!(hDC=GetDC(hWnd)))
return FALSE;
else
// o Device Context
if (!(hDC=GetDC(NULL)))
return FALSE;
// o Device Context
return FALSE;
// compatible DC
hDCMem = CreateCompatibleDC(hDC);
if (!hDCMem)
return FALSE;
// bitmap handle
if ((hBitmap = CreateBitmap(pRGB->width, pRGB->height, 1, 24, pRGB->rgb)) == NULL)
g_MainWindowInactiveDoNotClose=TRUE;
MessageBox( NULL, TEXT("CreateBitmap ERROR!"), NULL, NULL);
g_MainWindowInactiveDoNotClose=FALSE;
return FALSE;
// select object
if ((hOldObject=SelectObject(hDCMem, hBitmap)) == NULL)
MessageBox( NULL, TEXT("SelectObject ERROR!"), NULL, NULL);
return FALSE;
if (!BitBlt(hDC, g_preysize==120 ? 60 : 0 ,
g_preysize==120 ? 5: 0 ,
pRGB->width, pRGB->height, hDCMem, 0, 0, SRCCOPY)) //SRCCOPY
return FALSE;
SelectObject(hDCMem,hOldObject);
DeleteObject(hBitmap);
DeleteDC(hDCMem);
ReleaseDC (hWnd, hDC);
return TRUE;
//Fills up the RGB_Struct
VOID *AllocFileRGB(short width, short height)
RGB_Struct *pRGB;
pRGB = new RGB_Struct;
pRGB->width = width;
pRGB->height = height;
pRGB->rgb = (UINT8 *) malloc(width*height*3 * sizeof(UINT8));
return (RGB_Struct *) pRGB;
//Frees the memory allocated to RGB_Struct
void FreeFileRGB(RGB_Struct *pRGB)
if (pRGB->rgb)
free((void *) pRGB->rgb);
pRGB->rgb = NULL;
if (pRGB)
free((void *) pRGB);
pRGB = NULL;
Ying_S_Intel
Dear Customer,
Could you please submit this issue through our Intel Premier Support at https://premier.intel.com and our support engineer will look into your issue?
Ying
Intel IPP
