Is audio resample function in IPP?
Gaiger_Chen
HI :
I would like to reample audio signle by IPP.
the input is :
*pSrc by the format : CH1[0] CH2[0], CH1[1], CH2[1], CH1[2] CH2[3]....
input number channels(ex : 2), input sampleing rate(ex: 44100Hz), input bits per sample(ex: 16bit)
onput sampleing rate(ex: 44100Hz), output bits per sample(ex: 16bit) and channel length
output is
*pDst
I found IPP manual , there is only one channel resample.(or said, no this format resample function.)
So, may I ask, is there audio resample function for the format in IPP?
thank you.
Chao_Y_Intel
For iterleave data, you can use the deinterleavefunction to change it to mutiple single channel data, after processing these data, it can also use interleavefunction if needed:
ippsInterleave_
ippsDeinterleave_
Chao
Gaiger_Chen
HI
that is it , thank you !!
