Problems installing the Intel64 libraries
John_Stevenson-hoare
Has anyone else encountered problems installing the Intel64 libraries from the 7.0.1 download?
When I tried, after first installing the 32 bit libraries, the installer completed but no 64 bit folders and libraries were installed on my machine.
The installer showed a small yellow warning triangle when I expanded the list of items that it was going to install but provided no information as to what this meant.
I have VS2005 installed, and an earlier version of IPP (5.3.1), and my VS has the 64 bit extensions.
PaulF_IntelCorp
John,
Select that little yellow triangle and it should expand to a list. Once expanded, select the items you want to install (everything). And then you should find the bits you are looking for on your system.
I agree, I also found it confusing and have asked the install folks to make this more obvious.
Paul
Paul,
Thanks very much for your reply. You were right, I had to right-click on the yellow triangle and select to install the 64 bit stuff.
You would have thought that would be enabled by default as I was installing the 64 bit package!
Problem solved.
John
