Is sgx_aes_ctr reentrant?
Joongun_P_
In my enclave.cpp code, there is sgx_aes_ctr function calls.
When I executes my program, it works well but the execution time is not proportional to the 1 / (number of threads).
I tested with 7700k cpu and 1, 2, 4 threads.
Without sgx_aes_ctr calls, execution results are proportional to 4, 2, 1 times well.
I am using sgx sdk version 1.8 and I realize that the fuction is lapping of ippsAESEncryptCTR.
https://github.com/01org/linux-sgx/blob/1115c195cd60d5ab2b80c12d07e21663e5aa8030/sdk/tlibcrypto/sgx_aes_ctr.cpp
https://software.intel.com/sites/default/files/managed/f6/6f/ippcp_0.pdf
Why my programs execution time looks it doesn't?
Juan_d_Intel
It looks like you're not concerned about reentrancy but multithreading scalability, right?
Could you describe (or even better post) your code here showing how you measure sgx_aes_ctr  and ippsAESEncryptCTR execution times?
If your program is calling sgx_aes_ctr multiple times, the lack of scalability might be caused by the malloc/free calls. Since you're using the 1.8 Linux SGX SDK, you could use the tcmalloc library, instead of the default memory allocator included in sgx_tstdc. If that's not the reason, I'd like to see the test program to better understand what the issue might be.
Juan_d_Intel
Joongun_P_
After I replaced malloc to tcmalloc, execution times became scalable.
Thank you, Juan!
