6845 Discussions
Issue with converting from 16bit signed to 8bit unsigned while decompressing and reconstructing one multiframe image.
krushnaps
I am using intel IPP library for decompressing the JPEG. Internally I am using "ReconstructMCURowLS" method of the the class "jpegdec.cpp" for reconstructing the JPEG. Reconstruction is successful but while converting 16bit signed to 8bit unsigned, I am geting all the "pDst8u" 0xff instead of 0x00. And resulting all colours(near to black) becomes white.
Below is the code path which is getting executed......
if(m_dst.precision <= 8)
dstStep = curr_comp->m_cc_step;
pDst8u = curr_comp->GetCCBufferPtr(thread_id);
status = ippiReconstructPredRow_JPEG_16s_C1(
ptr,pPrevRow,pCurrRow,m_dst.width,m_ss);
status = ippiConvert_16s8u_C1R(pPrevRow,m_dst.width*sizeof(Ipp16s),pDst8u,dstStep,roi);
Here I am not getting the expected result i.e. status should be "zero".
I have doubt here, am I using the wrong method to convert from 16s to 8u? or anything wrong I am doing?
Can someone please help me in this topic?
Thanks and Regards
Krushna
Chao_Y_Intel
It looks the same one with this post. The question could be combined at that post: http://software.intel.com/en-us/forums/showthread.php?t=85096
Chao
