6713 Discussions
JPEG Encode fail on ippiEncodeHuffman8x8_JPEG_16s1u_C1
Kelvin
I use jpeg sample to encode image of size 720x480
as follows:
int linestep = img_w*3 + DIB_PAD_BYTES(img_w, 3);
encoder.SetSource(pBGR, img_w, img_h, 3, linestep, JC_BGR);
encoder.SetDestination(95, JS_444, JC_YCBCR);
errCode = encoder.WriteWholeImage(pJpeg, JPEGSize);
It returns internal error and debug mode report
IPP Error: ippiEncodeHuffman8x8_JPEG_16s1u_C1() failed - -62
It seems happen only on those image which we overlap
some line or text on it. e.g.
http://graphics.usc.edu/~tatchung/test.jpg
I also try JPEG samples 4.1 but same problem
happens. I'm using IPP 4.1.
Is it a known problem ?
- Kelvin
Vladimir_Dudnik
No, there were no such bug with IPP JPEG codec, can you reproduce this bug in JPEGView sample?
Note, you can see textual descripion of errors in ippdefs.h file. Here, status = -62 stands for ippStsJPEGOutOfBufErr = -62, /* Attempt to access out of the buffer */.
The reason can be not enough buffer size for output JPEG data. Can you increase buffer for compressed JPEG data?
Vladimir
Kelvin
Vladimir,
You're right ! Thanks for helping me
to solve the problem. :-)
- Kelvin
Vladimir_Dudnik
Hi Kelvin,
you are welcome:)
Vladimir
