LNK2026 Error : SAFESEH image
ysyoon
I am making a static library using IPP 5.1 version. This static library will be used in another DLL. Also I am using MS WDK6000 compiler.
After making a static library with IPP 5.1, there is any problem in making a librarybut when I link this with another DLL it gives me
[ error LNK2026: module unsafe for SAFESEH image. ]
How can I solve this?
Thanks in advance.
Vladimir_Dudnik
I think the issue is related to the fact that you use the latest build tools with the library which was built about two years ago.
Could you please try the latest IPP version which currently is IPP 5.2?
Vladimir
