6826 Discussions
Linux: IA32: 5.3.1.062 ipp, 5.3.072 samples, gcc4 Compile Failure
saialapati
I am getting following error when try to compile 5.3 samples. audio-video-codecs.
src/alsa_audio_render.cpp:58: error: 'snd_pcm_hw_params_set_rate_resample' was not declared in this scope
src/alsa_audio_render.cpp: In member function 'virtual UMC::Status UMC::ALSAAudioRender::SendFrame(UMC::MediaData*)':
thanks,
SAI
Vladimir_Dudnik
Hi Sai,
I created issue report on Intel Premier Support for you, so you will be updated regarding investigation status of reported problem.
Could you please specify what Linux distribution do you use, what is kernel version, do you have ALSA package installed?
Vladimir
saialapati
Red Hat Enterprise Linux AS release 4 (Nahant Update 1)
2.6.9-11.ELsmp #1 SMP
I installed ipps as the user not as root.
I have the following alsa installed:
alsa-lib-devel-1.0.6-5.RHEL4
alsa-lib-1.0.6-5.RHEL4
alsa-utils-1.0.6-3
Naveen_G_Intel
Alsa lib and alsa devel should be at least version 1.0.14 (Current version is: 1.0.15)
Use http://alsa-project.org/main/index.php/Main_Page to find a package exactly for your build and kernel
and this error should completely disappear!
In case of abnormal behavior after alsa lib was installed, please mail us
gcc4 version output as far as uname a one.
Thank you
Naveen Gv
