MJpeg decode problem
ynhuang
Hi
I use ipp 5.3 to write a program to dispaly stream from ip camera.
I got a problem of decoding mjepg. When Idecode the stream in attached file,UMC::MPEG4VideoDecoder::GetFrame() return UMC_ERR_NOT_ENOUGH_DATA. But this file can be played normally in VLC.
Does anyone knows why?And howdo Ifix this problem ?
Sergey_Ryadno
Quoting - ynhuang
Hi
Hi, I you sure that this file was encoded correctly? Than i try to play this stream with different video players, i found that the last bottom MCU row of each frame decoded erroneous. Do you see the same on yours VLC player?
