MPEG2VideoEncoder access violations
OTorg
New Contributor III
MPEG2VideoEncoderBase::Init() calls CreateFrameBuffer() to initialize/reinitialize internal frame buffers in the following cases only (OR):
  1. first initialization
  2. width/height changed
  3. color format changed
It doesn't take into account IPDistance parameter changes. So, the following code:
MPEG2VideoEncoder.Init( IPDistance = 1 );
... do some encoding work A ...
MPEG2VideoEncoder.Init( IPDistance = 3 ); // or Reset, then Init
... do some encoding work B ...
will get access violations or __non_rtti_object exceptions at work B (inside MPEG2VideoEncoderBase::FrameDone, LoadToBuffer), because the real size of frames.buf_B is 0 (instead of supposed size = 2).
Chao_Y_Intel
Hello, Thanks for you reported. I tracked this problem into to our defect database. Regards, Chao
OTorg
New Contributor III
Ok. And please look at one more defect: http://software.intel.com/en-us/forums/topic/343019
