MPEG4 encoder rate control
rramani80
Hi there,
I wanted to find out about the encoded Frame size parameter which existed in earlier releases but has been removed in ipp 5.2
Is there any alternative to the above ?
When rate control is enabled, my encoded frame size for 384 kbps (QCIF) is about 17,900 bytes.
I didn't see any reduction in size after going through the PostFrameRC function.
Is there anything else I should do ,so that the number of encoded bits are withing a certain size.
Ram
