MarkSpeckles maxPixDiff behaviour
MCGregor__Andrew
IPP18.1
Microsoft Visual Studio 2015
Does any body understand how the maxPixDiff paramter works in the markSpeckles function?
Using the test image below I expected that for the image
- threshholded at 8194
 - maxSpecklesSize of 300
That a maxPixDiff value of >25 would include the 'blue' (middle ring value 8240) portion of the image  however
- setting the value to 24 finds the centre portion as expected
- setting 26 finds NOTHING (not even centre portion)
- setting 80 finds NOTHING (not even centre portion)
Note this behaviour is evident on other images (actual data) not just this test pattern
Any help understanding this would be appreciated
Adriaan_van_Os
Maybe you hit a bug. I am using ippiMarkSpeckles with good results (but didn't create specific test-cases). The API of the function is somewhat peculiar in that it doesn't write to a separate result mask but inline to the image itself. Therefore, I let the user choose between black, white and mid-gray pixels.
My two cents.
Adriaan van Os
