ippiFilterBorder bug
Adriaan_van_Os
I noticed a bug in ippiFilterBorder where ippiFilterBorder_16u_C4R and ippiFilterBorder_16u_C1R (and rarely also ippiFilterBorder_32f_C4R and ippiFilterBorder_32f_C1R, but never ippiFilterBorder_8u_C4R or ippiFilterBorder_8u_C1R) write random pixels in parts of the last row of the target image when the convolution kernel has a width of 1 and a height > 1. The result seems to depend on the border type, but does happen with all border types.
The workaround is to apply a horizontal kernel (with height 1 and width > 1) to a transposed image and then to transpose the result back.
This happens with IPP version 9.0, but I can't reproduce it with version 2018-2 or 2019-0. However, I don't see an entry for this in the IPP bug fix logs. Can you confirm that this is something that has been fixed between version 9.0 and 2018-2 ?
Adriaan van Os
Ruqiu_C_Intel
Here Adriaan van Os,
Thanks a lot for raising the issue in old library IPP 9.0 legacy. We will double check the fixed bug logs internally.
BRs,
Ruqiu
Adriaan_van_Os
But can you confirm that this is something that has been fixed between version 9.0 and 2018-2 ?
Adriaan van Os
Ruqiu_C_Intel
Hello Adriaan van Os,
We did fix some ippiFilterBordersome bugs since version 9.0.
Ruqiu
