Meaning of parameters in perfsys
aegges
I just started the perfsys tool to measure the performance of the various FIR routines. However, I have some problems to interprete the results.
The CSV output for the ippsFIR_32fc() routine lists 3 different parameters. The first parameter parm1 is the tap len. But what are the other two parameters parm2 and parm3 with values of 1 or 2, respectively? There is nothing about them in the manual.
Any help would be appreciated.
Axel
Vladimir_Dudnik
Hello Alex,
there is comment from our expert:
- for parm2 and parm3 means single-rate FIR
1 or 2 for these parameters means UpFactor & DownFactor for multi-rate FIRs (one processing function ippsFIR but two different ippsFIRInit functions SR and MR it is mentioned in the manual)
Vladimir
