Memory leaks in IPP 5.2.049 samples ?
Maciej_K_
I'm testing H264 and MPEG4 samples from IPP5.2 and I found a few memory leaks:
MPEG4VideoEncoder::mp4enc is never deleted,
H264VideoDecode::m_pMemoryAllocator is never deleted ( m_bOwnAllocator is redefined so the same variable defined in BaseCodec is not visible, and BaseCodec::Close() is never called too ).
TaskSupplier::m_ppMBIntraTypes is never deleted,
if you do not provide VideoProcessing object to H264VideoDecoder it creates its own object, but it never deletes it.
Vladimir_Dudnik
thanks for pointing to these issues, we also have detected them (unfortunately after IPP 5.2 release), they will be fixed in the next, IPP 5.3 beta release, which is coming soon.
Vladimir
