Memory leaks in UMC base classes sample??
acolor0429
IPP version: 6.0.1.070
In the document"umc-manual.pdf", I follow the sample "Example 3-6 UMC Base Classes Usage"(page 3-127), write this sample program under VC2005. But no matter what mjpeg file I select, this programalways reports memory leaks, can any one tell me how to solve it?
ps. thetest media fileis download from here:
http://www.leadcodecs.com/Download/MCMP-MJPEG/WhatBox_360x240_411_q25.avi
VS2005 output message:
Detected memory leaks!
Dumping objects ->
{82} normal block at 0x018315E8, 24 bytes long.
Data: 68 CF B2 00 00 00 01 00 01 00 00 00 01 00 00 00
{80} normal block at 0x01831510, 24 bytes long.
Data: 68 CF B2 00 00 10 00 00 00 00 00 00 01 00 00 00
Object dump complete.
Vladimir_Dudnik
Thanks for reporting us on this issue. We will investigate it and update you with the results.
Vladimir
