6814 Discussions
IPP CP: Can't find struct _cpRSA definition in any header file
Vincent_S_Intel
I'm trying to use the RSA primitives in the IPP Crypto Library. So I create aIppsRSAState, however in ippcp.h this is typedef-ed from struct _cpRSA, which does not exist in any header file in the IPP CP package.
Can someone tell me what header _cpRSA should be defined in. An answer to why I could be missing it would be great, but the first part lets me at least investigate the second part.
Vinnie
Vladimir_Dudnik
This structure is hidden (implementation might be platform dependent). According IPP crypto manual (ippcpman.pdf, chapter 5 - Public Key Cryptography functions, p 5-70 RSA Primitives):
The application code for conducting a typical RSA encryption must perform the following sequence of operations, starting with building of a crypto system:
1. Call the function
RSAGetSize to get the size required to configure IppsRSAState context.
2. Ensure that the required memory space is properly allocated. With the allocated memory, call the
RSAInit function to initialize the context for the RSA encryption.
3. Keep calling the
RSASetKey to set up RSA public key (n, e).
4. Invoke the
RSAEncrypt function with the established RSA public key to encode the plaintext into the respective ciphertext.
5. Free the memory allocated for the
IppsRSAState context by calling the operating
Vladimir
franknatoli
Quoting - Vladimir Dudnik
3. Keep calling the
4. Invoke the
Vladimir
Where can one find any of the crypto H or C or CPP files?
My 6.0.0.062 ipp-samples has directory cryptographyopenssl-ipp, but src only contains three C files: timing_aes.c, timing_rsa.c and timing_sha.c. My IPP installation does not contain an ippcp.h file. Where can I find these files?
Vlad: who assigns the belt colors? If you aren't a black belt, the standard must be all wrong.
Vladimir_Dudnik
IPP Crypto library is separate install package (because of different license). You should specifically register for IPP Crypto on IPP main page to download IPP Crypto libraries and ippcp.h file.
I'm OK with color of belt, for me it is much more important to be able to help with IPP product than worrying about colors and belts :)
Vladimir
