6838 Discussions
Need a simple way to read and display image files (using IPP library)
teju_sanghavi
Hi All,
I've been struggling with some basic image interface stuff using IPP.
Please note that all the following questions apply to the linux system.
also I'm using the evaluation version of the 5.0 IPP version.
1. Can someone please tell me how to read an image file (eg. bmp or jpeg) into the IPP library, such that I can later use all the image processing functions on that file?
2. How to view an image file ?
I know that there is function called ipView. however, it's not available in the evaluation version for linux. There are some Windows examples on the Intel website that use IpView, but there is a tools.zip package provided which has the IpView defined. However, this only works on Windows.
Does anyone know how to make it work on linux ?
Is there is any other way to view an image, which has been obtained after performing all the computations by the IPP library ?
Any pointers/ideas/guesses etc. would be sincerely appreciated.
Tejas
Vladimir_Dudnik
Hi Tejas,
Actually we have a lot of samples which you can download from here:
http://www.intel.com/cd/software/products/asmo-na/eng/238686.htm
Regarding JPEG and BMP I can recommend you to take a look on JPEG Codingsamples, which are available for both Windows and Linux, and demonstrate how to decode and display JPEG images.
Vladimir
