Need to read .MCF file in stead of .WAV file
dirks
I noticed that the sample code is only capable of reading a .WAV file of a certain codec and transform that into another .WAV file of another codec. I'm looking into transferring a .MCF file in a certain codec into a .WAV file of GSM format (as example)
Is this supported by IPP and how do I do this?
thanks
ligoban
It is aninteresting question. You should convert your MCF into WAV.
Actually, what is that -MCF?
The WAV format is following: RIFF header and 16-bit PCM samples. If you know your MCF format - just read a little about WAV and make a converter.
