Noise reduction
nadavvolicon_com
I working on a speech oriented application, sampling rate is 11025 what IPP objects can I use for noise reduction?
ucs_nr demonstrate NR though sample rate are 8/16 Khz, can NR work with 11Khz as-well ?
N @ V
Ying_S_Intel
N @ V
The NR sample offered in Intel IPP mainly is to demonstrate how to use IPP for Noise Reduction, and our focus is to support a particular standard which requires 8K and 16K Hz speech codec.
So you may tryon your own to haveNR work with other sample frequency.
Ying
