Platform-Aware Functions overhead
BMart1
New Contributor II
Are _L variants slower? Will I get code bloat if I mix _L and normal variants of the same function? Or are both functions implemented only once underneath?
Shaojuan_Z_Intel
Hi Bruno,
The performance of platform-aware functions with _L variant should be comparable with the none _L functions for compatible systems. _L functions can overcome 32-bit size limitations. Can you explain why you'd use the same function with both variants? This link https://software.intel.com/en-us/node/684662 provides more information.
BMart1
New Contributor II
I already have some code using 32 bit functions I'd rather not update at the moment. I'm thinking of using_L functions for new code.
